Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
can't find log in icon in inventor 2010 with Vault Manufacturing
10 REPLIES 10
Message 1 of 11
771 Views, 10 Replies
Dear All,
I can't find log in menu from file->Vault Server. and I try to log in in the
"Vault" status, but it's just open Vault Manufacturing client.
I check in Inventor Add-in, it's display Autodesk Vault Add-in 14_0_63_0 for
Autodesk Inventor.
My System is WinXP 64 bits, with Inventor 2010 64bit and Vault
Manufacturing.
I try to reinstall Vault Manufacturing client, same problem with first
install(I had select "custom" to make sure to install inventor add-in).
Thanks and My Best Regards,
Jerome
10 REPLIES 10
Message 2 of 11
See attachment for the print screen.
"Jerome" wrote in message
news:6175713@discussion.autodesk.com...
Dear All,
Autodesk Inventor.
Manufacturing.
Jerome
Message 3 of 11
Hi Jerome,
Your screen capture indicates that the EDM Addin is not loaded. Navigate to
Tools tab and select "Add-Ins". Right-click in the "Add-In Manager" window
and select "Show Hidden Members". Once this is checked you will see "EDM
Addin" appear in the list. Make sure this addin is loaded.
Adam
news:6175889@discussion.autodesk.com...
Dear All,
Autodesk Inventor.
Manufacturing.
Jerome
Tags (1)
Message 4 of 11
Dear Adam,
I check as your mentioned, but I can't find "EDM addin". it's so strange
that I can find the login button in AutoCAD Mechanical 2010's Vault tool
bars.
is there any new suggestions?
My Best Regards,
Jerome
Message 5 of 11
That is strange that it is not in the list. The EMD addin is installed by
Inventor. I would suggest posting to the Inventor newsgroup to see if the
Inventor experts have some advice for you. I will continue to look into it
and respond if I find anything helpful.
Adam
news:6175997@discussion.autodesk.com...
Dear Adam,
bars.
My Best Regards,
Jerome
Message 6 of 11
Thanks!
I can find the new ICON as the attachment. but it's just load Vault
Manufacturing client, can't take login job.
Pls inform me when you have any update, thanks!
Jerome
Message 7 of 11
Madhan_T
Please run the following in MS-DOS window and let me know if this helps.
[DRIVE:]\Program Files\Autodesk\Inventor 2010\bin\Connectivity.InventorAddin.EdmAddinRegistration.exe /install
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
Message 8 of 11
Madhan_T
In my previous reply, please note [Drive:] is the location where Inventor application is installed.
Madhan
Principal Engineer
Autodesk, Inc.
Message 9 of 11
got and solved the problem, thanks,
Madhan!
Message 10 of 11
Madhan_T
You are welcome. Glad to hear that the issue has been resolved.
Madhan
Principal Engineer
Autodesk, Inc.
Message 11 of 11
DeconSmal
It took nearly all day to find out what why my login/logout icons were not showing in Inventor 2011. This post proved to be successful.
Jerome thanks for the question.
Adam thanks for the fix. This was very helpful.
