We have just switched from Vault 2012 to Vault 2014 and I want to bring over my custom views from Vault 2012. I can not find GridState.xml or ViewStyles.xml. I expected to find them here: C:\Users\username\AppData\Roaming\Autodesk\VaultCommon\Servers\Services_Security_1_28_2013\Localhost\Vaults\vault\Object
I have done this successfully in the past, I don't understand why I can not find the files this time.
I was able to locate my custom searches and shortcuts from Vault 2012.
I did a search of entire local drive for both files with no luck
Thanks in advanced,
Bob Wollenhaupt
Solved by herrerh. Go to Solution.
Try this path instead:
C:\Users\<username>\AppData\Roaming\Autodesk\Autodesk Vault <version> 2014\Servers\<servername>\Vaults\<Vaultname>\Objects
-Hywell
