Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Can't apply Vault Hotfix (DM1904910)
2 REPLIES 2
karthur1
295 Views, 2 Replies
I am trying to install the Vault Hotfix DM1904910.  I have already install this on the server and now trying to install it on the client machine.  When I run the .msp file, the setup hangs here (see below).  I started this yesterday afternoon.  When I came in this morning, it is still on this same screen.
I restarted the machine and tried it again, but it is still hanging at this same point.
Any ideas on what to do to get this to install.
Kirk
2 REPLIES 2
Senthil_Kumar
in reply to: karthur1
Kirk,
Can you please try this and see if this helps?
> Copy the Hotfix to the machine
> Disconnect the machine from Network
> Try the install and see if that works.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
karthur1
in reply to: Senthil_Kumar
Is it necessary to install DM1904920 is a cummulative update, I tried to install it rather than doing the DM1904910 first.  It also stalled as described in my original post.
I tried it again, but this time, I disabled my network connection.... that worked and the hotfix installed.
