Vault General Discussion
Employee
luttena
Message 11 of 20 (522 Views)
Re: Can not access vault from within Inventor
03-27-2012 08:58 AM in reply to: ro01
Nope. That should be fine.
Adam Luttenbacher
Sr User Experience Designer
ro01
Message 12 of 20 (510 Views)
03-27-2012 01:59 PM in reply to: luttena
I believe I have solved the issue. Its seems to be a registry error. Thank you for your help.
Active Contributor
tarrynd
Message 13 of 20 (389 Views)
11-05-2012 10:44 PM in reply to: luttena
Hi There
I have this same issue and I was wondering what were the steps that you took to correct your resgistry error?
Tarryn
ro01
Message 14 of 20 (385 Views)
11-06-2012 05:23 AM in reply to: luttena
I am sorry I don't remember the exact process, our Autodesk Vendor assisted us. I believe we deleted the Inventor and Vault directories out of the registry and let the applications rebuild the registry. I don't remember if there was another step.
Good luck
Active Contributor
tarrynd
Message 15 of 20 (381 Views)
11-06-2012 05:50 AM in reply to: ro01
Thank you very much for the reply.
Tarryn
Valued Contributor
DannyVanDuijn
Message 16 of 20 (276 Views)
03-01-2013 05:55 AM in reply to: tarrynd
I'm having the same issue.
All addins are loaded, even the hidden EDM and I have the Vault project file active.
Does anyone knows which registry keys must be adjusted /deleted?
Danny van Duijn
Doug_DuPont
Message 17 of 20 (201 Views)
04-30-2013 04:59 AM in reply to: DannyVanDuijn
 Danny,
I have just ran into the same problem. Did you resolve this? How did you do it?
Thanks for some help.
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
ro01
Message 18 of 20 (197 Views)
04-30-2013 06:09 AM in reply to: luttena
I believe what we did was delete the Inventor folder from the HKEY_CURRENT_USER\Software\Autodesk in the registry. Then when you start Inventor it will rebuild the registry correctly so it can communicate with Vault. Unfortunately this will remove any custom settings you may have done in Inventor. Remember to backup the the Inventor directory before you delete it just incase you are deleting the wrong folder.
Good Luck
Doug_DuPont
Message 19 of 20 (183 Views)
05-02-2013 04:26 AM in reply to: ro01
I found my problem,
In Inventor I when to the Addin's Panel, Right clicked and "Show Hidden Menbers"
The EDM Addin needed to be restarted.
Now Why this is a Hidden Addin I don't know? It is the only 1 that is Hidden?
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
Valued Contributor
DannyVanDuijn
Message 20 of 20 (167 Views)
05-05-2013 02:28 AM in reply to: Doug_DuPont
Hi Doug,
I did not solve it. The workstation was reinstalled (including OS) to solve several (performance) problems.
Of course this issue was resolved after the reinstall.
Danny
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
