I need to copy a design of a previous version in Vault. Is that possible? If not, how do I check out a previous version?
mjgky30SA,
Yes, in order to do a copy design on a previous revision or version, you can do the following.
-Hywell
Hywell Herrero
Product Support - Data Management
Novi, MI, USA
Autodesk Subscription - The smartest way to optimize your software investment.
I tried to copy a design of a previous version and it keeps copying the most recent version. We have tried to do this a couple of times and it doesn't work for us. Any suggestions? Thanks.
What version of Vault are you currently using?
If you using Revisions, please make sure that you open the revision that you just created by copying the original assembly. You can select a revision from the Revision drop down on the Open from Vault dialog. By default, Latest revision will be opened that will open the latest revisions of the children.
Hope that helps.
