Hi!
It´s possible to work with Autocad 2015 and Vault Basic 2014?
Or, the vault must be always in higher vertions regardind the cad software?
Thanks.
you can work with it but you will not get add on in Autocad 2015
you would need to be on Vault 2015 to get the add in for Autocad 2015
DarrenP
Thanks.
So, no addin, but can we check in check out directely from the vault interface to the workfolder, and open the files in acad 2015?
Hi Carlos,
I would recommend upgrading the Vault to 2015.
You should be on the safe side then and the workflow is much smoother and as it is designed.
