Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
BOM COMPARE REPORT
1 REPLY 1
jeamy.baena
524 Views, 1 Reply
BOM COMPARE REPORT
Hi, Experts
Is there a way to export or print a report that contain the comparison between two BOM versions? (which files were changed, deleted or added?). Now I only see tooltips or highlighted rows with those changes in the current display.
Thanks!!
1 REPLY 1
Hi Jeamy,
It seems like you're looking to export/print the information contained in the BOM Compare feature, correct?
Unfortunately, my research shows that the BOM Compare feature was not designed to allow the information to be exported. All comparison between BOMs were expected to be in the Vault client itself.
I do see a Vault IdeaStation post that may be relevant to what you are looking for. I would recommend upvoting this feature if you're looking to see it implemented in further Vault editions.
- Mike
