Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Bentley Microstation and Autodesk Vault tags-properties maping
2 REPLIES 2
1025 Views, 2 Replies
Does anybody knows how to map Tags from Microstation dgn file and Vault properties? Is this possible?
I am not expert in both Microstation and Vault, so any help would be good.
I added tags into dgn files and check them into Vault, but I do not see them in Vault properties, maybe I missing some steps?
2 REPLIES 2
tmoney2007
Hopefully you would set up the mappings in the administration menu like you do any other mapping.  Aside from that, I wouldn't know how to help you.
KooCheeKit
Yes, it is possible and required Vault Integration for MicroStation Client and Server 2014 to be installed. The mapping of MicroStation Tags to Vault User Defined Properties (UDP) is no different from mapping UDP at Vault Client Property Definitions dialog. Please refer to http://wikihelp.autodesk.com/enu?adskContextId=ID_PROP_NEWPROPERTY&language=enu&product=Vault&releas... for information on mapping properties.
Chee-Kit
Autodesk, Inc.
