My company uses numerical revs up to the delivery of product to the customer. At that point we bump all the drawing to Rev A. Is there a way to Batch Release from numerical to Letter Rev A in the Vault?
Bryan
Bryan
Hello Bryan,
The answer depends on what type and version of Vault you are using (ie. Vault Pro, Vault Basic etc.). It also depends on what type of lifecycle management you have set up in your Vault. If you have Vault Pro, do you use Items?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi Bryan,
Generally speaking, there can be several possiblities. I personally set up a vault with a revision scheme that starts with some set of numerical values and then continues with the alpha values. This allows a file to start at rev '0' or '1' and then you can manually push it up to 'A'. You can do this to multiple files at one time. Selecting all files that need to have their revision values updated, you can use the 'Revise' or 'Change Revision' command to display these files in the dialog box. You can set the first file to the 'A' rev and then copy it to all the other files.
Mark
Thanks Mark for the Response,
I was able to bring up the dialog box with multiple parts using the "revise" button but was unable to change the revision. is there a step i'm missing?
I do have Vault Pro not sure the version. we are using Items and doing all the Rev changes at the part not the drawing.
Bryan
I stand corrected. I recalled a way to more easily change multiple revisions. Upon further review, I can do it if using file-based revisions, but not item-based revisions. For item control, I can only pick one item at a time to revise. I will clarify that I am seeing this behavior in Vault Pro 2014. I believe the same behavior will be true for 2015. You might consider engaging someone that can create a custom application for Vault to automate the process.
Mark
