We are having our reseller quote some custom programs to solve this issue.
1st program will generate all of the various print files (pdf, stp, CSV boms, DXF), push the rev number, and check in the file. This is done after the idw is ready for release.
2nd program will run a "uses" report on a user-specified part number to get a BOM list from vault. It will then use the BOM list to colate all the required output files into a single zip file. All the individual component pdf files will be joined into a single multi-page pdf in that zip file. The user can then print the multipage pdf as required.
Steve Walton
Inventor 2023
Vault Professional 2023
