Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Batch plotting error with dwg files
3 REPLIES 3
347 Views, 3 Replies
Hi. Have you got an idea about this problem. I use the batch plotting of vault 2012, when I wan't to print dwg files, I've got a error : "The file was created with Autocad application. This application was not found on your computer". This message arrive only with dwg files. I can plot ipt, or iam with no problem. What can i do?
3 REPLIES 3
karthur1
just curious if you can open/plot those dwg files from Inventor?
herrerh
in reply to: karthur1
Is Autodesk TrueView installed on your machine?  If not please try to install it and then try batch plotting again.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
carrie.ruan
There is a known issue about the error on X64 system operation.
If your status isthe same issue, please try to install Omaha SP1 to solve it.
Carrie
