I wonder if it normal that about half of Tools-commands (including "Backup and Restore") are grayed out in console of servers that not belong to publisher's workgroup?
Could full backup be done from such server?
This is correct - there are a number of functions that can only be performed from the publisher. Many of which have to do with creating new vaults, etc. As you mention, the built-in vault backup and restore only works from publisher.
We do however support and document procedures for doing backup and restore from subscribers if re-replicating a subscriber from scratch would result in too much down-time (should the subscriber completely fail). Here is the white paper on that procedure:
Hope this helps,
Paul
I reviewed that section of the doc and didn't see any mention of '4 datasets' . So I don't completely understand the question. Could you clarify?
Paul
If you want to be able to restore the publisher, that is not sufficient. Most importantly, the subscriber backup lacks the distribution database (AutodeskReplication). Without that database it isn't possible to restore with replication. For the publisher you will need to follow the steps in the '
Backup Process for the Publisher' section.
Hope this helps,
Paul
While this is in theory possible, I don't think we have any documented procedures for doing so. Probably the best approach is to make sure publisher backups don't perish with the publisher - i.e. stored in redundant, off-site locations. Additionally if you periodically make ADMS console backups then those can be restored into a single site server configuration - people often do that to create separate test environments.
Paul
