One way is to use Windows Task Scheduler together with command line to purge file versions, from wiki:
-Opurge |
The operation being performed (required). If this operation is executed without any other switches, the task will run based on revision and lifecycle rules without affecting uncontrolled files. |
-Nvault name |
The name of the vault to be purged (required). |
-Stop |
Halts the purge task while it is running. |
-Normal |
Sets the purge task to a normal system priority. |
-KEEPVERSnumberX |
Keep the latest X number of versions (optional). The value can range between 1 and 99. The default value is 1. |
-MINAGEnumberX |
Purge versions older than X number of days (optional). The value can range between 0 and 180. The default value is 0. |
-EXCLCMTcomment |
Purge versions that do not contain the specified comment (optional). The default value is an empty string, "". |
-UNCONTROLLED |
Purges versions based on default settings and the revision and lifecycle rules. If used in conjunction with -KEEPVERS, -MINAGE, or -EXCLMT, then the system purges uncontrolled files as well as files based on revision and lifecycle rules. |
-VUusername |
Vault administrator account user name (required). |
-VPpassword |
Vault administrator account password (required). |
Example from Wiki
Connectivity.ADMSConsole.exe -Opurge -NVault -KEEPVERS10 -MINAGE180 -EXCLCMT"Do not purge" -VUadministrator -VPadmin
