Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autoloader with Vault 2012 Professional
1 REPLY 1
eclarkipp
338 Views, 1 Reply
I tried loading a bunch of files to the vault. 1.- Selected the folder I wanted to check in 2.- Scanned the files and evrything was fine no errors 3.- Selected the project I normally use 4.- when the sytem asks you what folder in the vault is the destination I came to realize that Autoloader is forsing me to use a project called designs. for tyhis reason I can not put the files where I want . Can anyone tell me what to do to make autoloader use the project I need?
1 REPLY 1
Senthil_Kumar
in reply to: eclarkipp
Refer the following link which should help you in this case
Mapping project to a folder other than the default folder when using Autoloader
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
