When using Autoloader, at the "map vault folders" stage, I see only "$" and "Designs". Yet when I log in to the Vault client , I see many more folders. Why can't I see the others?
Solved by cwhetten. Go to Solution.
By default Autoloader always maps to "Designs" folder. That is the reason you see only Designs folder during Map folder stage.
If you want to change it to other folder than Designs please follow the instructions from the following link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
Hi - sorry for late reply. I tried that , but it says "Buu.xml cannot be added due to vaulting rrestrictions - Buu.xml already exists in this project".
But I don't see the file anywhere except in the root of C:\
Looks like you have the BUU.XML already in the Vault. If you show the Hidden files in Vault you can see the BUU.XML at the Vault Root $. If you are sure this was done you and not used anymore you can delete and try again.
Hope that helps!
FYI, the link above doesn't work anymore. Use this link instead:
Cameron Whetten
Inventor 2014
