Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autoloader 2012
11 REPLIES 11
Message 1 of 12
dsmith
917 Views, 11 Replies
Autoloader 2012
Hi All
Anyone have any sucess in Autoloading Autocad files to Vault, I can autoload them but they never create a dwf visualisation file. Does anyone have a workround as I have 70,000 to autoload.
Thanks in advance
11 REPLIES 11
Message 2 of 12
Andy.Spivey
in reply to: dsmith
dsmith, when you executed the upload command in Autoloader, was the DWF set to be created?
Andy Spivey
SQA Engineer
Message 3 of 12
dsmith
in reply to: Andy.Spivey
Yes it was, if you try it it does not work, The customer only has basic Vault so I cannot use the job server method
Message 4 of 12
Senthil_Kumar
in reply to: dsmith
You might have done it. But wanted to double check. Did you check the "show Hidden files" option in the Vault Explorer?
Also if possible please send me a sample file for test purpose. You can send it to senthilDOTkumarATautodeskDOTcom
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Message 5 of 12
dsmith
in reply to: Senthil_Kumar
You can try the simplest of drawings from autocad, there is no dwf created or uploaded to Vault. Give it a try and you will see
Message 6 of 12
Senthil_Kumar
in reply to: dsmith
Thanks for your reply. I can see the issue. DWF creation is failing with the message that Layout is not Initialized. But it is failing even after Initializing the layouts manually.
I am forwarding this to Development.
Thanks for reporting this issue.
Senthil Kumar
Autodesk, Inc.
Message 7 of 12
dsmith
A prompt fix for this would be of help as I have 70,000 dwgs to Vault
Dave Smith
Message 8 of 12
Richard.Rankin
in reply to: dsmith
Hi Dave,
I am probably tempting fate by updating this thread before anything is released in case there is a problem, but can you re-test after applying ts17763847?
It should be released shortly.
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
Message 9 of 12
ndra
in reply to: Richard.Rankin
We're having the same problem, any news on the update Richard? What issues does it fix exactly?
Nikos
Message 10 of 12
dsmith
Any news on when this will be available. I am happy to beta test if it helps
Message 11 of 12
Senthil_Kumar
in reply to: dsmith
You can get the Hotfix from the following link.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17895647&linkID=9261341&CMP=OTC-RSS...
Senthil Kumar
Autodesk, Inc.
Message 12 of 12
ndra
Dear Kumar,
Works like a charm. Many thanks.
Nikos
