On Sat, 25 Oct 2008 22:20:48 +0800, LarsS wrote:
> In article <6056975@discussion.autodesk.com>, me@autodesk.com says...
>> Hi Lars,
>> From the log file, it appears that fbp.dll is missing.
> Hi Keng
> I looked searched in the log-files. The references to fbp.dll I found,
> told the file was
> existing???
> Which file & line number are you refering to??
> I checked and could verify that fbp.dll is in the bin dir.
> A strange thing is that there are quite many dll duplicates (incl.
> fbp.dll), but in different
> versions & timestamps, see attached screenshot from a synchronizer (I
> didn't synchronize,
> however)
In your attached file, Filemon_autoloader.log, fbp.dll is reported not
found starting from line 9908. Its a bit odd that your Inventor directory
was not probed for
the file. As a workaround, you might want to consider adding Inventor bin
directory to your system path environment and see if that works for you.
Keng Leng
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
