Vault Forum
Welcome to Autodeskā€™s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Showing results forĀ
Did you mean:Ā
Autodesk Vault Workgroup 2012 - LogIn Screen / server name
1 REPLY 1
Styrop14n
388 Views, 1 Reply
Hi All
On the Login window there are :
user
password
server
database
I got problem with setting up a server name. I've tried put ACADSERVERPATH=myservername in the ini file in [Vault] part, then I've edited mst CONFIG_TRANSFORM=VaultWkg.mst and add this property, but each time the server section on the Login windows is empty.
Please let me know how to setup server to appear for end user.
Thx.
1 REPLY 1
JamesMcMullen
in reply to: Styrop14n
I would modify the following file:
C:\Users\<UserName>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\ApplicationPreferences.xml
I am not 100% sure if that would keep the vault server present if the user never logged in.  There might be other things that are required.
-Jim
James McMullen
Principal SQA Eng.
