Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autodesk Vault "View In Window" function runs AutoCAD instead of viewer
1 REPLY 1
marshallw
807 Views, 1 Reply
Right-click any DWG file in Vault Professional 2014 & select "View In Window" from pop-up menu forces AutoCAD Mechanical to open instead of the "DWG True View" viewer. DWG viewer IS installed on client machine.
Any ideas, anyone?
Autodesk Inventor Certified Professional
Autodesk Inventor Certified Instructor
1 REPLY 1
edwin.prakoso
in reply to: marshallw
That's because your DWG launcher is set to AutoCAD Mechanical. It looks like you installed ACM after TrueView.
You can change this behaviour by modifying registry. See this DWG launcher fix by John Evans.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
