I'm running vault 2012 and I can't see the file or folder names when I set the layout to detail view. The files are there because the icons that display the vault status show up and if I hover my cursor over the row it will display the file name. When I switch the layout view to small or large icons everything displays fine. Any ideas?
Solved by herrerh. Go to Solution.
Try the following to reset you view settings.
Right click in the header area (column list)
Select Customize view
Reset
