Gentlemen:
Please help me to recover the commands in Autodesk Vault Ribbon, they were not funtion any more, and I don't know what was happen. It used to funtion ok after It mapped to the Vault a few day ago. Please see attachments.
Please help me to recover it so I can check-In to the Vault or insert parts from the Vault. Thanks
I am a CAD Admistrator at Anemostat (A Metesk Company)
Solved by inventor_ton. Go to Solution.
Solved by mollons. Go to Solution.
In the add-ins dialog try right clicking and showing the hidden add-ins.
Make sure the EDM add-in is also set to loaded and to load automatically.
Gentlemen:
I am the one was asked you about "Autodesk Vault Commands was no long funtions", it was solved yesterday. Now, the EDM is disappeared in the Add-In Manager and of couse the commands in Autodesk Vault are not funtions. Please help again. I am so appreciated you help. Please see attachment.
Huan
For those who might still be stuck:
Another issue we ran into that had our IS stumped was the .ipj file from the Vault. A few times Inventor will switch to the default.ipj project file instead of designs.ipj from the Vault. This grayed out all of the Vault commands as well.
