Hey, I have attached the logs and copy and pasted a few lines from the file into my post.
EDIT: I'm adding some additional information about the server it's running on:
MSSQL 2005 Express
Windows Server 03
I also found this in the knowledge base ID: TS1059334 but I'm not sure how much it applies since my server is running MSSQL2005EXPRESS. I looked through the solution explained and I have very few files in the...\80\ folder but all the files in the ...\90\Shared folder.
2/18/2010 3:05:14 PM mid: 634021023142399224 code: 0 , Connectivity.Core.Exceptions.SysErrCodes.UnspecifiedSystemException System.NullReferenceException: Object reference not set to an instance of an object.
at Connectivity.Web.Services.DocumentService.GetFileAssociationsByIds(Int64[] fileIds, AssociationRelationEnum relation, Boolean recurse, Boolean includeHidden)
2/18/2010 3:05:37 PM mid: 634021023372866499 code: 0 , Connectivity.Core.Exceptions.SysErrCodes.UnspecifiedSystemException System.NullReferenceException: Object reference not set to an instance of an object.
2/18/2010 3:05:51 PM mid: 634021023513646848 code: 109 , Connectivity.Core.Exceptions.CoreErrCodes.DatabaseError System.Data.SqlClient.SqlException: Failed to load Msxmlsql.dll.
Could not find prepared statement with handle 0.
sp_xml_removedocument: The value supplied for parameter number 1 is invalid.
The statement has been terminated.
at Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
at Connectivity.Core.Database.SqlAccess.ExecuteReaderInternal(SqlCommand cmd)
at Connectivity.Core.Database.SqlAccess.ExecuteReader(CommandType commandType, String commandText, SqlParameter[] commandParameters, Int32 commandTimeout)
at Connectivity.Core.DataAccess.Director.InvokeSproc()
at Connectivity.Core.DataAccess.Director.ExecuteSQL()
at Connectivity.Core.DataAccess.Director.Execute(Options options)
at Connectivity.Core.DataAccess.Director.Execute()
at Connectivity.Document.DataAccess.Files.GetLatestFilesByMasterIds(Int64[] masterIds)
at Connectivity.Document.Services.FileService.GetLatestFilesByMasterIds(Int64[] fileMasterIds)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Edited by: leegrisham2500 on Feb 18, 2010 9:49 PM
