Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autodesk vault API 2012 - check-in file bug ?
2 REPLIES 2
570 Views, 2 Replies
In Vault 2011, when we invoke:
File CheckinFile (
    Long fileMasterId,
    String comment,
    Boolean keepCheckedOut,
    DateTime lastWrite,
    Long [] dependFileIds,
    String [] dependSources,
    Long [] attachFileIds,
    String [] attachSources,
    BOM bom,
    Boolean copyBom,
    String newFileName,
    FileClassification fileClassification,
    Boolean hidden,
    System.Byte [] fileContents
and specify newFileName different (than actually checked out file has), in file history we can see that:
VersionFile name
1sample1.txt
2sample2.txt
But unfortunately, using Vault 2012 and making the same operation usign API the result is:
VersionFile name
1sample2.txt
2sample2.txt
Is this purposeful behavior or maybe a bug ? Can anobody tell me? Smiley Indifferent
2 REPLIES 2
Redmond.D
This is not a bug.  Starting in Vault 2012 renaming a file will now retroactively rename all versions of the file.  This behavior is in all of the Vault clients and the API as well.  There is a new property called "File Name (Historical)" that contains the original file name.  At the API level, File.VerName has the original file name.
Doug Redmond
Software Engineer
in reply to: Redmond.D
Hi Doug,
Thanks for the answer! Smiley Happy
Mike
