Righto girls & boys, Vault workgroup, Professional and Basic are all available for download in the subscription center. You can find out what's new here.
Mine is already installed 🙂 So I'll be mucking about with it next week.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Solved by cbenner. Go to Solution.
Doesn't show up in my upgrades yet. 😞
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Voila! There it is! Downloaded, waiting for IT to finish setting up my shiny new test server so I can play around with this. Now all I need is my PD Suite!
Chris Benner
you maybe waiting until Mid April for the suites
DarrenP
I might be able to hang on that long... not sure.
Chris Benner
just testing to see if the Vault 2015 add-in will work with Inventor 2015 RC. I can't wait until mid april.
Scott Moyse
The Vault 2015 add-in installs into Inventor 2015 RC. It's untested though, so AVOID it for production work.
Scott Moyse
scott
does your Thin client work for vault 2015?
DarrenP
yes from client pc's, but I can't get it to work on localhost/server. I haven't tried troubleshooting that, it may not be supported.
Scott Moyse
yep thats how we are running it
this is how the 2015 Beta was to
DarrenP
figured this out
apparently the Vault Thin Client is an optional install under tools & utilities
DarrenP
oh ok. Well I had it installed. As soon as I did install it, I could access it from my workstation, but I can't browse to it on the server it's installed on. Hence the Localhost access comment I made.
Scott Moyse
I downloaded it from the Subs Site, It's often but not always in the Tools & Utilities section of the installer. I just checked and it is included in the install media for the Product Design Suite Ultimate and Factory Design Suite Ultimate. I would imagine it would be for the lower editions as well.
Scott Moyse
Thanks Scott,
I did find it in the Tools and Utilities of the install pack. But since my server is remote, it would be much easier with just the VSB install file.
So I assume you don't have the option to download it from your subs site? double check under Product Enhancements, it has appeared there in the past.
Scott Moyse
No, it isn't listed on the Sub site anywhere I can find. With 2014, it was in the Tools and Utilities, but it was also listed separately in enhancement downloads here: http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=21542159
But there is no 2015 software there. (yet)
I am having the same issue. I am needing to install Vault Basic Server 2015 and have PrDS 2015.
Only thing that is showing up under product enhancements is Vault 2014.
I dont have alot of time to get this tested and into production.
You will need to start "Setup.exe" for the PDS 2015, and at the opening screen, click "Install Tools & Utilities". You will find it there.
