Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autodesk vault 2013 Failed to aquire a license
6 REPLIES 6
tanveer4m
1418 Views, 6 Replies
I install the Vault server & client in my server. Server consol is running fine but for client it is "failed to acquire a license"
Any help
Tanveer
Autocad Draftsman
6 REPLIES 6
Senthil_Kumar
in reply to: tanveer4m
Check this solution
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13107015&linkID=9261340
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
tanveer4m
in reply to: Senthil_Kumar
I have done all the changes suggested but the problem remain same. no change
Thanks for looking at my state
Tanveer
Autocad Draftsman
cbenner
Have you restarted the license server?  I have notice, for an as yet unknown reason, that our server will randomly shut down and need to be restarted.  IT is helping me track when this happens to see if we notice a pattern... so far nothing.
What type of license server do you have?    Is it configured to be redundant?
minkd
Can you look in the vault log (vlog) on the ADMS host for the time period when you got the error?
Also, in the same folder as the vlog there should be a licensingLog.txt file that will have additional information.
With the combination of the two, I might be able to tell why it isn't getting licenses.
-Dave
Dave Mink
Fusion Lifecycle
DarrenP
in reply to: minkd
did you create a license file for Vault Pro 2013?
DarrenP
