Geting the following error message when trying to install Autodesk Vault 2011 (Server) onto a Windows XP 32bit machine.
ASPX file failed to run at URL:http://localhost:80/TestASP/TestASPNet.aspx
Log file says -
Checking ASP Status - Accessing a static file through the http protocol has passed. ASPX file failed to run at UL:http//localhost:80/TestASPNet.aspx.The remote server returned an error (500) Internal Server Error.
Launching http://localhost/TestASp/TestASPNet.aspx in IE returns the following -
Could not load file or assembly 'System.Web.RegularExpressions, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
Any help greatly appreciated.
