I came in this morning and the Vault interface seems to have dissapeared in AutoCAD. I have reinstalled the Autocad addin in the add/remove features of Vault client, I have uninstalled Vault Client and reinstalled Vault client. Works fine in Inventor. All Products are 2009. Works on another machine. The Open from vault option on the Autocad pulldown is greyed out, as is the login / logout. I can launch the Vault explorer from Autocad pulldown. I can open, check in and check out files from Inventor.
Any help will be greatly appreciated.
The 'Open from Vault' at pulldown should not grey out whether login or logout. Maybe could try reloading the Vault menu, at Acad cmdline, enter 'menuload', and Unload 'Vault' from Loaded Customization Groups. Then Browse VaAc.cui file from '%userprofile%\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Support', and then Load it.
Hope this helps,
