Hi All,
Is it just me, or has the option to view & download File Attachments disappeared from the new Vault Thin Client (Subscription Extension1)?
In the old web client, there used to be an Attachments tab where you can see the list of attachments, and download them as well.
In the new thin client, all I see is a line item showing me that there is an attachment, but no way to download it?
Thanks!
Solved by Zoe-Yao. Go to Solution.
Thanks for your feedback!
There is no Attachments tab as the old Web Client. Instead, Thin Client shows attachments under the Uses tab. The screenshot below is for your reference. You can get the attachment files via Actions contextual menu -> Download.
Hi Zoe-Yao,
Thanks for your comment. I realised the issue is because the attachment has no lifecycle attached to it, and as such is not in the Released state. The Thin Client is set to have only Released revisions showing, hence it is not displaying the non-released attachment.
This is a change of behaviour from the old Web Client, as with that, even if the attachment is not Released, it will still display.
Is this the as-designed behaviour of the new Thin Client? If so this is quite an inconvenience - particularly in the scenario where the attachment is generated by the Job Processor (e.g. CoolOrange powerJobs to generate PDF's). We will have to put in new categories and rules to automatically release these files.
That being said, there may be some benefits to these - ensuring attachments are Released before making them available to the Thin Client.
Thanks and BR,
Carlos
Hi Kolesaa, I'm tried it with IE10 and Chrome 32 - same result.
Though for this release, I prefer using IE witht the Thin Client as there is more functionality available with it. For example, in Chrome, you can't see the DWF preview file, only a thumbnail.
Hi Kolesaa,
All the browsers supported by Thin Client like IE, Chrome and FireFox should be working in this case.
Best Regards
Zoe
Hi Carlos,
Currently such behavior is regarded as designed. Our development team will follow up these concerns you raised. Thanks so much for your valuable feedback!
Best Regards
Zoe
Regarding the Visualization Preview in Thin Client, we are working on this function improvement for other browsers than IE. If everything goes well, it should be enhanced in the next Vault release. Appreciate your bringing up such valuable concern.
Zoe
