Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Attachments in Thin Client Issue
5 REPLIES 5
Esky99!
391 Views, 5 Replies
It seems if I select an idw attachment within an item, it tries to open the idw file instead of the dwf file?
Need help here thanks.
Paul
5 REPLIES 5
chearhuat
in reply to: Esky99!
Hi Paul,
Could you check if the idw has its own DWF generated?
If not, you might have to turn on 'Create Visualisation Attachment' while checking-in the design data from from inventor.
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Be sure to check out the Vault Help Wiki!
Esky99!
Hi Chear
It has a dwf file attached because I can open it works fine in old web client.
Regards
Paul
chearhuat
Hi Paul,
We're bringing this setting 'to restrict downlaod of [design] file with visualisation attachment' in Vault 2015 release, which will serve this requirement.
You might want to to turn it on, and re-examine the behaviour.
Chear Huat.
Chear Huat
SQA Analyst
Esky99!
in reply to: chearhuat
Hi Chear
Sorry for the confusion. Are you saying I need to upgrade to 2015 to see the dwf file?
Thanks Paul
chearhuat
Hi Paul,
Yup.
You may use the setting to determine if your user could download (see) visualisation attachment or design data.
Chear Huat.
Chear Huat
SQA Analyst
