Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Assign Item problem...
5 REPLIES 5
282 Views, 5 Replies
Hello All,
I have a released '.iam' file, and associated '.dwg' file, that I'm trying to assign an item.  for some reason it does not autolink the '.dwg' files to the '.iam' on this one.  Others that have been done do not have the problem.
I've gone through this combo, comparing it to previous ones that have worked and all properties seem to match.
Does anybody know of another reason why this link wouldn't be made?
5 REPLIES 5
cbenner
in reply to: cbenner
it is Vault 2013 Pro.  The designer created the '.iam' & '.dwg' file; released them in the project explorer, selected both the '.iam' & '.dwg'; clicked "assign item".
cbenner
by Auto-Link I mean that in "Item Master" when you select the item line, the General tab shows both the 3D (.iam or .ipt) model and the associated '.dwg' file together.
the problem I'm having is it creates an individual item for both the '.iam' and the '.dwg' file, but the item for the '.dwg' file is a randomly generated 6-digit number.
scottmoyse
Has someone turned off the option to attach related documentation? I don't think you need to select both files to assign the item. By doing so you are explicitly instructing vault to create an item for the documentation. However by just selecting the iam it will see the relationship and attach it as a secondary attachment.
You can disable the assignment of items to drawings in the admin options if I remember correctly
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
