Hello All,
I have a released '.iam' file, and associated '.dwg' file, that I'm trying to assign an item. for some reason it does not autolink the '.dwg' files to the '.iam' on this one. Others that have been done do not have the problem.
I've gone through this combo, comparing it to previous ones that have worked and all properties seem to match.
Does anybody know of another reason why this link wouldn't be made?
What version of Vault are you using, and can you please describe the workflow you used?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
it is Vault 2013 Pro. The designer created the '.iam' & '.dwg' file; released them in the project explorer, selected both the '.iam' & '.dwg'; clicked "assign item".
I guess I'm not sure what you mean by "autolink"? Both the assembly and dreawing were successfully assigned to Items?
Chris Benner
by Auto-Link I mean that in "Item Master" when you select the item line, the General tab shows both the 3D (.iam or .ipt) model and the associated '.dwg' file together.
the problem I'm having is it creates an individual item for both the '.iam' and the '.dwg' file, but the item for the '.dwg' file is a randomly generated 6-digit number.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
