I have an assembly: floor, left side and right side (Left Side Mirror). I want to vault up the assembly; the floor and up the left side, but the right side (left side of the mirror) is unsuccessful. Give Error Messages.
Solved by Soporte_CAD. Go to Solution.
More attachments.
Thank you for replying
Hi there,
I notice the file path and file name may be an issue here - can you check the length of this filename (test by reducing name length) and retry.
Gracias olearya , el problema era el SO, esto era W8.1. fue cambiado a 8.0 y todo va bien.
