Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
API: Get file id by file name
6 REPLIES 6
rjwinkelman
1295 Views, 6 Replies
I am new to using the Vault API. Many API functions require a fileid or fileMasterid. From my position I am starting out with a file name. I must be overlooking something or missing a concept. I don't see a function like GetFileIDByName. I have created a sub using FindFilesBySearchConditions to get a file by it's name. Is there a function that you give a file name and file ID(s) are returned?
6 REPLIES 6
in reply to: rjwinkelman
The search is indeed your best solution.
It is possible [depending on your configuration] to
have multiple files with the same name. So there is not necessarily a 1-1
mapping between file name and ID.
Paul Gunn
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
ID(s) are returned? Thanks
rjwinkelman
Thanks for the explanation Paul, I can now shake the feeling that I was overlooking something else. We are going with unique file names, so I'll create my own front end subs based on names.
Rich
If you know the full Vault path, FindLatestFilesByPaths is a good function
to use.
If you just have the name, FindFilesBySearchConditions, like you are
currently doing, is a good option. Another option is to use
GetLatestFilePathsByNames which will give you all the matching File objects
and the Vault path.
NOTE: A file can be shared across multiple folders.
Doug Redmond
Software Engineer, Autodesk Inc.
rjwinkelman
Thanks Doug, I'll give those functions another look.
rjwinkelman
Felix-Saibel
"GetLatestFilePathsByNames": it's a great hint, I was was look for quite a while, also
