Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Anybody attempted Vault client 2013 and Windows 8 yet?
17 REPLIES 17
Message 1 of 18
2235 Views, 17 Replies
I'm curious is anyone has had success running the Vault 2013 client on Windows 8 yet or not. I know the issue with .NET 4.5, and that Autodesk doesn't support this yet, but I'm wondering if anyone has figured out how to make this work?
Yes, I already upgraded to Windows 8 and am in the middle of figuring out what works and what doesn't... Hah! 🙂
Scott
17 REPLIES 17
Message 2 of 18
I'm curious, as the more I read the more I get confused... From what I can see, both .NET 4.0 and 4.5 are installed on Windows 8. If this is the case, why doesn't the Vault client run successfully? Does it not use 4.0? Or is it becuase 4.5 is there in the first place? Spoken like a true .NET noob to be sure...
Message 3 of 18
DarrenP
i am running windows 8 in a VM i will try to install vault 2013 client on it
DarrenP
Message 4 of 18
DarrenP
in reply to: DarrenP
i just tried it the problem is there where the files don't show up
i tried turning off .net 4.5 didn't work
DarrenP
Message 5 of 18
DarrenP
right now it doesn't work with Windows 8
unless someone knows a workaround
DarrenP
Message 6 of 18
Thanks for looking into this, Darren. I have tried a few things, and can't get it to work either. I heard a rumour that someone managed to get Vault and .NET 4.5 to work together on Windows 7 (something about running Vault in debug mode), but I haven't seen anyone figure out a workaround in Windows 8 yet... Here's hoping someone much smarter than me can figure it out, haha! 🙂
Message 7 of 18
ihayesjr
Windows 8 only come with .NET 4.5 and you can't uninstall it nor install 4.0 alon side of it. Vault 2013 is not supported on Windows 8.
Irvin Hayes Jr
Sr. Product Manager
Vault - Under the Hood Blog
Message 8 of 18
in reply to: ihayesjr
I realize that, but almost all the posts and articles I am reading say that 4.5 supports apps written for 4.0, so I'm not sure what is going on with Vault not working... But, I'm not a programmer so what do I know? Anyways, I do know that Autodesk is trying to fix Vault so that it works with 4.5, so I'm hoping that is very soon...
Message 9 of 18
We've done some tests, It could depends from a control library used by the Vault Client, it is not compatible with .net framework 4.5
You will have the same problem if you install the .net framework 4.5 on windows 7
Gianalberto
Message 10 of 18
IT-BWTEC
ou s*** and i'm running win 8, tryed also to deactivate .net 4.5 but also didn't work ... 😞
that's really bad luck now ... any new ideas?
Message 11 of 18
I haven't had any success with this. I would've thought this would be enough time for a patch to come out, but I guess not! 😞
I don't use my machine for production work, so when I need Vault access I use it via a virtual machine on Hyper-V that has Windows 7 still on it. NOT an answer for production work though to be sure...
Unfortunately, Autodesk can often be "slow to the punch" when it comes to new technology (multi core processors anyone?), so I'm not sure if I'll be holding my breath...
Message 12 of 18
in reply to: IT-BWTEC
I'm not so shure but I think there's no way to deactivate 4.5 on win 8.
We have to wait for sp1
Message 13 of 18
DarrenP
vault 2013 sp 1 is out its supposed to fix this issue with .net 4.5: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341
DarrenP
Message 14 of 18
That is awesome, I will try that tonight and report back!!!
Message 15 of 18
ihayesjr
Although this fixes .NET 4.5 this does not provide support for Windows 8.
Irvin Hayes Jr
Sr. Product Manager
Message 16 of 18
IT-BWTEC
With the SP1, Vault Basic 2013 seems to work fine on my Win8-machine.
Goodbye Hyper-V 😉
Message 17 of 18
onebadcad
Are there any plans for this to be supported in the future?
Message 18 of 18
DarrenP
in reply to: onebadcad
probably not
2014 is the first to support windows 8
DarrenP
