I can see why the higher res would allow you to see it. Could it be due to
you running at this higher res first, then lowering the res later when the
problem became apparent? As for deleting the folders/xml files, that should
resolve any problems you have by essentially resetting everything to the
out-of-the-box defaults, but you have to exit out of Vault Explorer, delete
the folders, then re-start Vault Explorer for it to work. That's the only
caveat I can think of..
Bob
wrote in message news:5084241@discussion.autodesk.com...
Just informing you of another fix.
I deleted the vault common and Vault explorer folders in the documents and
settings folders, to no avail.
I then changed my screen resolution to the highest res, and the advanced
find suddenly re-appeared, dont know why.
Any ideas why?
