Rick,
If the dialog box seems to be "active" but not on your screen you can delete
the files from this folder. Exit Vault Explorer, delete the files, re-start
Vault Explorer, now your dialogs/etc should appear in the default locations.
C:\Documents and Settings\\Application
Data\Autodesk\VaultExplorer\Objects
This should do the trick.
Bob
wrote in message news:5076835@discussion.autodesk.com...
When the "find" toolbar is toggled on the options pulldown selected and
"advanced find" enabled, the button on the windows task bar appears, but the
dialog box is no where to be found. Our IT department claims it's not off
the screen and cannot figure out how to locate the dialog box (we cycled
through alt-tab and tried all sorts of screen resolutions). We uninstalled
and reinstalled the vault client, but the same problem persists with this
particular user. Has anyone experienced this problem - or have a suggestion
as to how to fix it? Much thanks in advance.
Rick
