Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
ADR Browser plugin - Thin Client 2015
18 REPLIES 18
Message 1 of 19
Esky99!
2697 Views, 18 Replies
I have the browser plugin installed and am still geting a message saying:
"Autodesk® Design Review Browser Add-in is not available to display this content."
Any ideas here thanks?
Paul
18 REPLIES 18
Message 2 of 19
bharath.kumar99
in reply to: Esky99!
Hi Paul - May I ask you to share details of the web browser and the version you are accessing Vault thin client 2015?
Bharath Kumar
Message 3 of 19
Esky99!
in reply to: bharath.kumar99
Google Chrome
Version 32.0.1700.107 m
Message 4 of 19
Esky99!
Message 5 of 19
bharath.kumar99
Hi Paul - I see the version you are using is outdated.
Follow the below Steps please  –
  1. Update your Chrome browser to the latest version "Version 34.0.1847.131 m".
  2. Do a clean un-installation of Autodesk Design Review.
  3. Install latest verion of Autodesk Design Review.
  4. Make sure you have "Autodesk Design Review Browser Add on v1.2" in your machine, by navigating to "Control Panel\Programs\Programs and Features"
Bharath
Bharath Kumar
Message 6 of 19
Esky99!
Hi Bharath
I have completed what you mentioned and still have the same issue. Smiley Frustrated
Regards
Paul
Message 7 of 19
chearhuat
Hi Paul,
This is an known issues, that we had already adressed in upcoming release.
The workaround is to install ADR desktop in the server machine, so that it will recognise the visualisation files accordingly.
Let us know then.
thanks.
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 8 of 19
in reply to: chearhuat
I had the same issue and stumbled upon this post.  I installed ADR 2013 on the Vault Server machine and it fixed the issue for me.  Thanks for the suggestion.
Message 9 of 19
scottmoyse
Are you referring to an upcoming release of Vault or the plugin?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 10 of 19
DanSingleton
in reply to: scottmoyse
Still happening with 2016 Thin Client in Chrome, even with ADR installed on the server.
Message 11 of 19
3DAli
in reply to: DanSingleton
same thing here, Vault pro 2016, FDS2016 and still no luck with this and nobody can use thin client in our organization efficiently and we were sold on this functionality!:(
Signature_Small
Message 12 of 19
scottmoyse
I can't believe this is broken again.
Scott Moyse
Message 13 of 19
3DAli
Scott,
can you really help me to resolve this, web client is kind of useless without this and I need this sorted out. we dont have enough vault lisences for everybody to connect and its realyy frusttrating, I have done all the suggested fixes, add ins, you name it, but it just doesnt work. I appreciate if you have any idea, share
Cheers
Signature_Small
Message 14 of 19
scottmoyse
in reply to: 3DAli
I can't fix the bugs. But doesn't it even work with Internet Explorer?
Scott Moyse
Message 15 of 19
3DAli
firefox, chrome, IE all failed, any other browser that I can try?
Signature_Small
Message 16 of 19
3DAli
in reply to: 3DAli
unbelivable, just tried IE and it worked, I swear to God it was not working, I must have done something
I dont kow, but I guess you broke this spell 🙂
Thank you 🙂
Signature_Small
Message 17 of 19
scottmoyse
in reply to: 3DAli
Good!! In any case, this should be working with the other browsers and the ADR plugin.
Scott Moyse
Message 18 of 19
DanSingleton
"Should work" is something Autodesk need to rid from their vocabulary.
This thing is SO buggy it is next to useless. I get different behaviours depending on both browser used and the file type being viewed. I also get different results depending on the PC I'm logged in on.
Chrome:
.ipt: "Autodesk® Design Review Browser Add-in is not available to display this content." OR useless Pop-Up with preview image
.iam: "Autodesk® Design Review Browser Add-in is not available to display this content." OR useless Pop-Up with preview image
Inventor .dwg: "Autodesk® Design Review Browser Add-in is not available to display this content." OR useless Pop-Up with preview image
AutoCAD .dwg: Useless Pop-Up with preview image
FireFox:
ipt: Properly displays preview of file in new tab OR useless Pop-Up with preview image
iam: Properly displays preview of file in new tab OR useless Pop-Up with preview image
Inventor .dwg: Properly displays preview of file in new tab OR useless Pop-Up with preview image
IE (11):
ipt: Displays in new tab but has huge white bar across preview of file (ribbon that isn't displaying correctly?) OR useless Pop-Up with preview image
iam: Displays in new tab but has huge white bar across preview of file (ribbon that isn't displaying correctly?) OR useless Pop-Up with preview image
Inventor .dwg: Displays in new tab but entire screen is white until you click in it OR useless Pop-Up with preview image
As a recent convert to Vault Pro I am certainly not happy with this. It is most definitely not worth the extra money we paid speciifcally to go to Pro so we could use the Vault Thin Client throughout our shop. We should have stuck with Vault basic. At least it worked and didn't have all the extra overheads involved with Vault Pro.
Message 19 of 19
Carl_mgfx
Hi all
I'm having these exact same issues with 4 Vault Pro servers and their respective client machines!!  Is there a way to get this to work?  We are running Vault Pro 2017 and have only managed to get the thin client to function fully on Firefox with the ADR v1.2. plugin.  I've tried Internet Explorer 11 and Chrome Version 54.0.2840.99 m with different results.  See attached images.
Kind Regards
Carl van Rooyen
Application Engineer
Inventor 2019, Vault 2019,
HP ZBook 15u G4, Win 10 64Bit (ver 1709), i7-7500U, 16 GB Ram
Intel HD Graphics 620 with AMD Firepro W4190M
