I have the browser plugin installed and am still geting a message saying:
"AutodeskĀ® Design Review Browser Add-in is not available to display this content."
Any ideas here thanks?
Paul
Solved by chearhuat. Go to Solution.
Hi Paul - I see the version you are using is outdated.
Follow the below Steps please ā
Bharath
Hi Bharath
I have completed what you mentioned and still have the same issue.
Regards
Paul
Hi Paul,
This is an known issues, that we had already adressed in upcoming release.
The workaround is to install ADR desktop in the server machine, so that it will recognise the visualisation files accordingly.
Let us know then.
thanks.
Chear Huat.
I had the same issue and stumbled upon this post. I installed ADR 2013 on the Vault Server machine and it fixed the issue for me. Thanks for the suggestion.
Are you referring to an upcoming release of Vault or the plugin?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Still happening with 2016 Thin Client in Chrome, even with ADR installed on the server.
Scott Moyse
Scott,
can you really help me to resolve this, web client is kind of useless without this and I need this sorted out. we dont have enough vault lisences for everybody to connect and its realyy frusttrating, I have done all the suggested fixes, add ins, you name it, but it just doesnt work. I appreciate if you have any idea, share
Cheers
Scott Moyse
Scott Moyse
"Should work" is something Autodesk need to rid from their vocabulary.
This thing is SO buggy it is next to useless. I get different behaviours depending on both browser used and the file type being viewed. I also get different results depending on the PC I'm logged in on.
Chrome:
.ipt: "AutodeskĀ® Design Review Browser Add-in is not available to display this content." OR useless Pop-Up with preview image
.iam: "AutodeskĀ® Design Review Browser Add-in is not available to display this content." OR useless Pop-Up with preview image
Inventor .dwg: "AutodeskĀ® Design Review Browser Add-in is not available to display this content." OR useless Pop-Up with preview image
AutoCAD .dwg: Useless Pop-Up with preview image
FireFox:
ipt: Properly displays preview of file in new tab OR useless Pop-Up with preview image
iam: Properly displays preview of file in new tab OR useless Pop-Up with preview image
Inventor .dwg: Properly displays preview of file in new tab OR useless Pop-Up with preview image
IE (11):
ipt: Displays in new tab but has huge white bar across preview of file (ribbon that isn't displaying correctly?) OR useless Pop-Up with preview image
iam: Displays in new tab but has huge white bar across preview of file (ribbon that isn't displaying correctly?) OR useless Pop-Up with preview image
Inventor .dwg: Displays in new tab but entire screen is white until you click in it OR useless Pop-Up with preview image
As a recent convert to Vault Pro I am certainly not happy with this. It is most definitely not worth the extra money we paid speciifcally to go to Pro so we could use the Vault Thin Client throughout our shop. We should have stuck with Vault basic. At least it worked and didn't have all the extra overheads involved with Vault Pro.
Hi all
I'm having these exact same issues with 4 Vault Pro servers and their respective client machines!! Is there a way to get this to work? We are running Vault Pro 2017 and have only managed to get the thin client to function fully on Firefox with the ADR v1.2. plugin. I've tried Internet Explorer 11 and Chrome Version 54.0.2840.99 m with different results. See attached images.
