Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
ADMS won't open
17 REPLIES 17
Message 1 of 18
elise_moss
2341 Views, 17 Replies
ADMS won't open
I am trying to open the ADMS so I can set up a custom content center for my company.  We are using Inventor 2011.  I have the Vault Client on my laptop as well as Inventor Professional.  I log in to the company's server.  I see the desktop icon/shortcut for the ADMS, but when I click on it, it immediately closes...any ideas?  I don't even get to the login screen.
thanks!
17 REPLIES 17
Message 2 of 18
elise_moss
in reply to: elise_moss
Description:
  Stopped working
Problem signature:
  Problem Event Name:    CLR20r3
  Problem Signature 01:    connectivity.admsconsole.exe
  Problem Signature 02:    15.0.58.0
  Problem Signature 03:    4b748062
  Problem Signature 04:    System
  Problem Signature 05:    2.0.0.0
  Problem Signature 06:    4a275e12
  Problem Signature 07:    f36
  Problem Signature 08:    239
  Problem Signature 09:    IOIBMURHYNRXKW0ZXKYRVFN0BOYYUFOW
  OS Version:    6.1.7600.2.0.0.16.7
  Locale ID:    1033
This is the data that is in the error dialog.  I am on Windows 7.
Message 3 of 18
mollons
Is someone else logged into the server and have ADMS Console open?
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 4 of 18
elise_moss
in reply to: mollons
Guess I will go around the company and check...Smiley Surprised
Message 5 of 18
Andy.Spivey
You can login to the server and open task manager - under the processes tab ensure "show processes from all users" is checked, and see if connectivity.admsconsole.exe is running under a seperate user.
Andy Spivey
SQA Engineer
Message 6 of 18
elise_moss
in reply to: Andy.Spivey
Thanks - that is HUGE help!
Message 7 of 18
elise_moss
Description:
  Stopped working
Problem signature:
  Problem Signature 06:    4d352ea2
  Locale ID:    1033
Nobody is logged in and I am still unable to access the ADMS.  Any ideas?
Message 8 of 18
elise_moss
Andy - I have yet to be able to get into the ADMS to set up custom content.
Nobody is logged in.  I log in to the remote server, click on the ADMS short cut and it won't launch.
I haven't been able to figure out how to access processes on the remote server.
thanks,
Message 9 of 18
Andy.Spivey
elise,
If you login to the server via the console, does the crash still occur?
Andy Spivey
SQA Engineer
Message 10 of 18
elise_moss
yes
Message 11 of 18
Andy.Spivey
Can you attach the log files?  maybe there is a .net issue or other information that we can use to pinpoint the problem.
Andy Spivey
SQA Engineer
Message 12 of 18
gRanid
We have same problem. But my sistem Win srv 2008r2 standart sp1 & Vault Basic 2014. Where i can find log files, to attach them?
Message 13 of 18
gRanid
in reply to: gRanid
There is logs.
Message 14 of 18
gRanid
in reply to: gRanid
Warning before following the steps below please read post 16 below Warning
"Deleting the \ProgramData\Autodesk\VaultServer folder could delete your filestore if it's located in there, which it is by default.  That would destroy your Vault and delete all your files. "
Edited by
Discussion_Admin
The best way to fix this problem -
1)uninstall Autodesk Vault Server
2) and manualy deleting  folders
c:\ProgramData\Autodesk\ADMSVault\
c:\ProgramData\Autodesk\VaultServer\
c:\Program Files\Autodesk\ADMS 2014\
c:\Program Files\Autodesk\Data Management Applications\
3) Instal Autodesk Vault Server
Message 15 of 18
jon.overbeek
And now the rest of the story .... ?
I have exactly the same issue.
Message 16 of 18
Neil_Cross
in reply to: jon.overbeek
What have you tried doing already to fix it?
Under no circumstances follow the advice in the post above by gRanid unless you know your Vault server and exactly how your Vault is installed.  Deleting the \ProgramData\Autodesk\VaultServer folder could delete your filestore if it's located in there, which it is by default.  That would destroy your Vault and delete all your files.  Careless advice, that post should be removed.
Message 17 of 18
jon.overbeek
in reply to: Neil_Cross
Got it figured out.
The SQL server services for AUTODESKVAULT was stopped.  Trying to login with an invalid account.
I went to Services -> SQL Server (SQLEXPRESS) and I saw that it was stopped.  I started and it gave a login error.  In properties, Log On Tab, I changed Log on as to Local System account, then started the SQL service.
Jonathan Overbeek, ACI
Message 18 of 18
Andy.Spivey
Hi Jonathan - glad your environment is running again.
It may be benificial to find the root-cause of the SQL stoppage.
A possible example being, if the Database engine was running as .\SQLDBE1 and the account was locked, it may be that the password simply changed, or someone was trying to access the system with invalid credentials...
Andy Spivey
SQA Engineer
