Our server ran out of disk space yesterday, so space was cleared out of the C:\ drive ~ 50 GB currently available. I restarted our server, but access to our server from the Vault 2010 client side yields the following error:
"Autodesk Vault 2010 could not find the Data Management Services on XX.XX.X.XX."
From the server side, ADMS console 2010 is running fine, but when Tools -> Administration is selected, the following error message shows up:
"Autodesk Management Server Console 2010 could not find the Data Management Services on 127.0.0.1."
When accessing http://127.0.0.1/autodeskdm services/securityservice.asmx, message shows:
"Could not load file or assembly "Connectivity.Platform' or one of its dependecies. There is not enough space on the disk. (exception from HRESULT: 0x80070070) - see attached
Is there a solution to this problem short of reinstalling ADMS?
Given that the ADMS-Console works until you go to Tools/Administration it would appear that SQL Server is up and running fine, but IIS may not be. I recommend re-starting IIS.
-Dave
