I believe this is what you are looking for:
5/17/2007 8:09:44 AM ==================================================================
5/17/2007 8:09:44 AM Logging initiated: Core server version 12.0.123.0
5/17/2007 8:09:44 AM Unable to check ADMS system state. After closing this message box, you can press F5 to try again.
If the error condition continues, contact your IT administrator.
__________________________
Illegal pathname or filename.
IllegalPath
5/17/2007 8:09:44 AM Connectivity.ADMSConsole.exe Information: 0 : Tracer for 'Exceptions' created.
5/17/2007 8:11:00 AM Illegal pathname or filename.
Connectivity.Application.VaultManager.ServiceException: IllegalPath ---> Connectivity.Core.Exceptions.CoreException: IllegalPath
Server stack trace:
at Connectivity.Core.Util.ConfigReader..ctor(ConfigSource configsource)
at Connectivity.Core.Util.ConfigServiceUtil.GetConfiguration(String sectionname)
at Connectivity.Core.Util.DatabaseConfiguration.Instance()
at Connectivity.Core.Security.SystemPrincipal.ResolveDatabaseName(DatabaseReqs databasereqs)
at Connectivity.Core.Database.Transaction._TransactionDatabase..ctor(DatabaseReqs requirements)
at Connectivity.Core.DataAccess.LegacySystems.DetermineKVMName()
at Connectivity.Core.DataAccess.LegacySystems.LegacyTransaction._TransactionDatabase..ctor()
at Connectivity.Core.DataAccess.SiteCompatibility.GetSiteCompatibilityWithKnowledgeMaster()
at Connectivity.Core.Services.KnowledgeMasterService.GetSiteCompatibilityWithKnowledgeMaster()
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Application.VaultManager.KnowledgeMasterService.GetSiteCompatibilityWithKnowledgeMaster()
--- End of inner exception stack trace ---
at Connectivity.Application.VaultManager.ConfigUtil.InitializeSystemState()
5/17/2007 10:55:10 AM ==================================================================
5/17/2007 10:55:10 AM Logging initiated: Core server version 12.0.123.0
5/17/2007 10:55:10 AM Unable to check ADMS system state. After closing this message box, you can press F5 to try again.
