Greg,
This Microsoft Article will help fix this problem.
http://support.microsoft.com/kb/894435/en-us
Irvin
gblake wrote:
> Another "Not an IT guy"...
> I am getting the same errors as above. I have configured what I can per the error help file, but when I get to this step
> "ASPX Access
> ASPX file failed to run at URL: "http://localhost/TestASP/TestASPNet.aspx".
> The test ASPX did not run properly. Re-register the ASP.Net filters. At the command line, enter: c:\windows\microsoft.net\framework\v2.0.50727\aspnet_regiis -i
> Also, check to make sure that the default web site is using version 2.0 of ASP.Net. To change this setting, right-click My Computer and then select Manage. In the Computer Management window, expand Services and Applications > Internet Information Services > Web Sites and then right-click Default Web Site and select Properties. In the Default Web Site Properties dialog, click the ASP.NET tab. From the ASP.NET version drop-down list, select 2.0. "
> there is no ASP.net tab. I've uninstalled .NET 2.0 (it reinstalled by itself like it's supposed to), but run into the same wall.
> attempting to install on WinXP64.
> Eagerly awaiting ANY help I can get on this...
> Greg
