I'm new to Vault Professional 2015 and was wondering if there is a way to add an entire folder of Revit families (and its sub-folders) to Vault. Currently, the only way I know how to add a family to the Vault is to open it in Revit, then "Save to Vault". Is there another way? I'm not using the Revit Server in conjunction with Vault, only Vault.
Mike
Solved by herrerh. Go to Solution.
In the Vault Ribbon within Revit you should see the Add Files button with a down arrow. Hit the down arrow and there is an option to Add Folder.
-Hywell
