Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Add new Vault properties to Report Template?
2 REPLIES 2
Winks87
691 Views, 2 Replies
We recently consolidated properties in the Vault and added some new ones.  The new properties need added to a transmittal report.  How is this accomplished?  I am using the fyi reporting "rdl designer" and cannot see the new properties to add to the report template.  Autodesk?
James Winkler
2 REPLIES 2
Redmond.D
in reply to: Winks87
Here are the steps:
  1. Save a copy of the RDLC files you want to modify.
  2. Go to the Explorer folder of your Vault client install.
  3. Run ReportTemplateAuthoringUtility
  4. Log in
  5. Run the File->Open command and select the RDLC file.
  6. Select the properties you want to use in your report.
  7. Save your changes and exit the utility.
  8. Open the report template in an RDLC editor.
  9. You should now be able to use your new properties in the grid.
Doug Redmond
Software Engineer
Autodesk, Inc.
Winks87
in reply to: Redmond.D
THANK YOU! (yes, I'm shouting).  Exactly what I was looking for in a clear step by step order.  Excelent work.
James Winkler
