Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Accounts of trusted domain are not shown as member of domain group
7 REPLIES 7
Message 1 of 8
Maxim-CADman77
1033 Views, 7 Replies
Our company network configuration counts several trusted domains.
We used to use domain groups that include accounts from different domains.
ADMS console doesn’t show members that doesn’t belong to domain of the group while OS does show accounts from both domains.
Example
there are 2 domains:
   DomainA
   DomainB
There is a Domain A group
   DomainA\TheGroup
with two domain users included
   DomainA\User01
   DomainB\User01
ADMS is a part of DomainA and it's OS sees the group all correct two members.
ADMS console shows the only user in the group - DomainA\User01.
What might be wrong.
PS: At leas once Vault showed that same group with both members.
PPS: Autodesk Support CaseNo is 08285515, but I don't feel like getting support to this issue with their usuall half-year/case speed so any ideas are welcome.
7 REPLIES 7
Message 2 of 8
Further testing..
There is two groups:
   DomainA\Group01
   DomainB\Group01
Both groups have same set of members:
   DomainA\User01
   DomainB\User01
Vault sees incomplete content for each group:
  DomainA\Group01 only DomainA\User01
  DomainB\Group01 only DomainB\User01
Any ideas?
PS: Vault Pro 2013, Service Pack 1
Message 3 of 8
MaxU77
in reply to: Maxim-CADman77
The update for topic headline issue:
Vault adds account of trusted domain to domain group on login of the user (that is ok)
Vault removes account of trusted domain from domain group on group update operatien (wrong behavior).
But there is also second issue with usage of trusted domain accounts within domain groups:
If trusted-domain-user is given modify access to replicated folder DIRECTLY – everything is OK on both publisher and subscriber ADMS.
But if trusted-domain-user is given modify access to replicated folder VIA DOMAIN GROUP then everything is ok on ADMS-publisher but only READ access to that same folder on ADMS-subscriber.
MaxU77,
AI2011 Certified Associate
(Soft: PDSU2012, VP2012&VP2013)
Message 4 of 8
ihayesjr
Can you provide screen shots showing the permission difference on the publisher folder and the subscriber folder?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 5 of 8
in reply to: ihayesjr
Surely! I'm now 3 weeks waiting for somebody from Autodesk asking me for some details (weanwhile have prevented several attempts to close the case without denying the problem existance).
Which way do you prefer to get those screenshots:
1. Post em here (not desirable as it will mean share publicly names of our server, database and user);
2. Attach them to the mentioned case.
3. Pass it to you in some alternative way (to your mail etc)?
Message 6 of 8
ihayesjr
Attach them to your case.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 7 of 8
Dear Irvin Hayes
I've uploaded the screenshots.
Thank for your interest and hope to hear from you.
Message 8 of 8
Maxim-CADman77
Issue is actual in Vault 2017. Steps to reproduce:
  1. Setup Vault for two connected WorkGroups (trusted domains).
  2. In Active Directory of subscriber’s WG create account “UserOfSubscriber”
  3. In Active Directory of publisher’s WG create account “UserOfPublisher”
  4. In Active Directory of publisher’s WG create group “Designers” containing the two accounts
  5. Open ADMS console; import «Designers» group (give it «Document Editor (Level 2)» Role; give it access to the Vault; make sure it is enabled).
BTW make sure only “UserOfPublisher” is shown as a member (no “UserOfSubscriber” is present).
6. Run VE as “UserOfPublisher” and make sure he:
   6.1 does have edit permission while connected via the Publisher
   6.2 CAN’T connect via the Subscriber
7. Run VE as “UserOfSubscriber” and make sure he:
   7.1 does have edit permission while connected via the Publisher
   7.2 CAN’T connect via the Subscriber
8. In Vault create local Group “DesignersLOC” containing the two accounts (give it «Document Editor (Level 2)» Role; give it access to the Vault; make sure it is enabled).
9. Run VE as “UserOfPublisher” and make sure he now does have edit permission while connected via the Subscriber.
10. Run VE as “UserOfSubscriber” and make sure he now does have edit permission while connected via the Subscriber.
