someone could help me,
I want to pass to vault the manufacturer property of components in acade drawing to vault. (for example a fuse manufacturer)
I try to find this property in vault setting properties -> mapping acade project to item. I found only component name , component type, line1 etc. but not manufaturer.
I didn't found the solution,
I try to explain me better, I need to put the property "manufacturer" of components (this property is a field in db access of acade 2013) into vault pro 2013 property. If I go in Vault setting -> Properties and I create a new property "mfc", I can't map the acade component "manufacturer" to vault "map". I only found component name, component type, line1, line2 ... I tried also to check wd.env but nothing. Any idea?
Thanks for any help.
Its been a while since we setup our ACADE to Vault but if I remember correctly to map component properties you don't use the the ACADE Project. The Project file is only used to map properties of the project to Vault like the Project title and description. I think you want to map to an actual drawing that contains components with the properties you want to map
Mike
Not sure if this is what you're looking for, but it might help?
http://cbennertipstricks.blogspot.com/2013/08/autocad-electrical-creating-items-in.html
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Mike is correct.
Asscoicate the property name with Item | Electrical. The component is inserted into the dwg, hence select a dwg with component to import and map (see image attached). Hope this is what you are looking for.
