Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
A little direction for a novice please.
4 REPLIES 4
daveafossil
863 Views, 4 Replies
I am learning all about AutoCad Vault 2012. I need to perform some administration duties like giving myself a log in 'user name' and a 'password'. But first, I have to find out how to become the vault administrator. Mine is a single computer, single user system that will ultimately transmit and receive documents from local offices. Also any information about "server" and "database" would be helpful. It is still a bit blurry for me at this point.
David
4 REPLIES 4
csmac2004
in reply to: daveafossil
Hey!
Is the Console installed on your system, or on a seperate server? If your own system, you can use "localhost" as the server name. Typically, I believe "Vault" is the default vault name.
As for admin user access, the default Admin user should be able to be used to create another admin user of your choosing. When creating a user, select the "Administrator" option when setting up roles and you will have complete admin control on your vault. I'm sure there's a document regarding this, I'll see if I can dig something up.
Scott
Scott MacDonald
Inventor 2013 Product Design Suite
Vault Professional 2013
Windows7 x64
Autodesk Inventor Certified Professional
daveafossil
in reply to: csmac2004
Scott MacDonald
Thanks very much for the info. Very usefull. As I read more and dig in more, things become clearer. TTT things take time.
Best regards
David
csmac2004
There are some good articles and whatnot on Autodesk's Wikihelp: http://wikihelp.autodesk.com/enu
And here's the link for Vault: http://wikihelp.autodesk.com/Vault/enu/2012
I haven't looked around the Vault one in particular, but the one that jumped out at me right away was this: http://wikihelp.autodesk.com/Vault/enu/2012/Help/02._Working_with_Vault/02._Vault_Server/1001BasicAd...
I hope that helps, feel free to ask away though!
Scott
Scott MacDonald
Windows7 x64
DarrenP
here is the vault implementation guide:
DarrenP
