Running Web Client in IE 11...
When you pick to view the files in ADR within IE, all I get is the thumbnail to pop up in window. How do I get it to pull up in ADR within IE as another tab?
Solved by zongjie.ng. Go to Solution.
Hi Steve,
I noticed that you posted a similar issue on Chrome at http://forums.autodesk.com/t5/vault-general-discussion/2015-web-client-chrome-pulls-up-thumbnail-rat... and you have resolved the issue yourself due to the wrong server pointed. Does that resolve the IE issue as well?
Otherwise, I may require some more information from you. Does the files have visualization file created? etc.
I think this might have been the case too...was still pointing to the VP2014 server. I made sure it was going to VP2015 and seems to be working now.
Thank you,
Steve H.
