We have found that the new thin client in 2015 does not allow us to only search items. This was a preferred configuration in the old web client. The users could only search items and then only access the attached files. In the new thin client, I have tried to use the same settings, but I continue to see the Project Explorer and can navigate or search files. Is there a way to disable this?
Mark
Mark,
I am not seeing what you are seeing. If you select the Item Master then perform your search, it will only return Items.
Irvin,
I think the OP is saying that in prior releases, the admin could set up the screens so that ONLY the Item Master was shown to the user. Or only the Project Explorer, as they needed. In this new release, I'm also not seeing where the admin can set what is visible to users, and what isn't. But I've only opened it for a few minutes so I probably am just not seeing it yet?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
The ability to see the Item Master or the Project Explorer is based on the user's role now.
Hey Irvin,
Thanks for the reply. Just to clarify my experience and testing, I am in 2015 and I am using the Guest account for testing. I have configured the web client to show released items and effective revisions for released items, but I have not checked the box to show released file versions. I configured the Guest account as an item reviewer only, and it is not in any group.
I log in as Guest, into the web client, and I see the project explorer folders, I can navigate through the folders. I see files regardless of their association with items, and regardless of the item's state. WIP items' files are visible, can be previewed, and downloaded. I suspect that this is not the intended behavior, for those clients that use item-based control.
Mark
Ah! That makes sense then.
Chris Benner
Has there been any update to this discussion? We follow an item centric release process. In the thin client, If I check the "released file versions" option, item attachments are not downloadable as well. If I un-check the "released file versions" option, then item attachments are downloadable but unreleased files versions are now accessible via project explorer. Either of these settings are undesirable.
