I Vault Explorer, when I select an Inventor assembly file, then go to the "Uses" tab, I would like to see what parts are used in each version of assembly. There is no way that I can find, to show this informaion. The "Uses" tab only shows the Latest, and it is greyed-out so I cant select it.
What do I have to do to be able to see the historical information?
Kirk
Kirk
Get a TARDIS?
Sorry... that's actually a very good question!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
When we added File Revision functioanlity to Vault Workgoup and Pro, we made the choice to focus on Revisions and mostly hide the idea of Versions from the user. We decided that showing both versions and revisions would be overly confusing to the user.
This pull down will only allow you to select revisions of the file. Until the file has revisions the pulldown will be disabled.
But it is possible to see the information you are after in a different workflow.
If you go to the history tab and choose to show all versions, then select a version (other than the latest) and select the Get Revision command.
Expand the dialog to show all the options.
You will then notice that instead of Latest or a Revision the pulldown will show a version number.
The tree structure is the Uses information for that version of the file.
Mikel,
Thanks for that explanation. I was trying the workflow you outlined, but I cant find the "Get Revision" command. It is probably because there are no revisions for the assembly. If thats the case, I would think that the command would be there, just be greyed out.
Kirk
Sorry wrong command name.
Get / Checkout is the command.
